Platform: B-Body
transmission issues
Old Dec 7, 2009 | 4:40 PM
x69x442x's Avatar
Default transmission issues
Hey, I am new to the forum but it seems like there is a lot of knowledge here....so maybe you guys can help? I have an 86 caprice. I recently swapped a 70's 350 into it. While I had the tranny(stock 700r4) out I figured I would throw a shift kit(B&M if it matters) in it.
Now here is my problem... I have no reverse on my transmission and it seems to slip really bad in the forward gears. I called b&m and the service tech said check the pressue regulator valve. I am almost 100% sure I put the valve together correctly and put the snap ring in the groove. Does anyone have any suggestions of stuff to look at before I take the pan off? Fluid is at the correct level. Could the vaseline I used to hold check ***** in place for installation be an issue? By that, I mean could it be holding them and not allowing them to move. Any help would be appreciated..
P.S. The transmission worked in ALL gears prior to removal...
joeysworld
10
Apr 7, 2021 9:05 PM
Coravir
Oct 26, 2019 3:28 PM
01yeehaw94
Mar 29, 2008 8:41 PM
