Captiva The Captiva has been sold worldwide since 2006 and now comes to the US to replace the Saturn Vue
Chevy Captiva
Platform: Theta
2012 Captiva 2.2D wont start when MAF sensor connected
Old May 21, 2022 | 10:39 AM
mng's Avatar
mng
Default 2012 Captiva 2.2D wont start when MAF sensor connected
Hello
Captiva 2012. 2.2D 120kW
Car won't start when MAF sensor is connected. When I pull out a plug from the MAF sensor, the car starts but of course the power is limited and the engine check light goes on
I tried to replace the MAF sensor with the new one but it doesn't help
Any advice what could be the problem?
Thanks
Old May 21, 2022 | 1:38 PM
hanky's Avatar
You could replace parts till the cows come home and still not find or correct the problem.
What is required is someone with the knowledge , info and equip to chase down the cause of the problem.
Today's vehicles don't leave much room for tinkering as older models did. They are a little more complicated to troubleshoot.
If there is insufficient power available to components that use vehicle reference voltage , plugging in a good MAF sensor may be the straw that breaks the camel's back by pulling that voltage down and not allowing other components to work as intended.
It could be a simple cure, the trick is to find the cause.
Old May 21, 2022 | 3:25 PM
mng's Avatar
mng
I agree with you.
Next week I'll visit a service shop with GM support and I hope we'll find a problem.
Old May 25, 2022 | 9:05 AM
mng's Avatar
mng
Me again...
The problem was caused by broken inter-cooler turbo hose pipe. This is the second time I had to change the same part.
Thanks for help
Old May 25, 2022 | 2:25 PM
HHR guru's Avatar
Originally Posted by mng
Hello
Thanks
captiva?? Make sure you replace the cam shaft sensors... buy them on Amazon
Old May 25, 2022 | 2:26 PM
HHR guru's Avatar
Hello
Thanks
kmahlobogoane
Captiva
Apr 3, 2022 3:35 AM
Denis Djordjevic
Captiva
Jun 6, 2020 12:01 PM
Vueluv
Captiva
Aug 27, 2018 3:49 PM
Maureen Scudieri McMurry
Captiva
Apr 6, 2016 12:55 PM
Sarhang
Captiva
Jun 8, 2015 12:12 PM
