Captiva The Captiva has been sold worldwide since 2006 and now comes to the US to replace the Saturn Vue
Chevy Captiva
Platform: Theta
Hard engine start
Old May 19, 2023 | 5:23 AM
Keresztes Tamas's Avatar
Default Hard engine start
I have a 2007 2.0 Captiva,and it's starting very hard,but once it is started,there is no problem and the second start is always normal,good.But after 1 day,again the first start is the same(hard,I have to try a second time to start)here in Romania nobody knows this problem,please help me
Old May 19, 2023 | 5:45 AM
Welcome from Florida. It sounds like the check valve in the fuel pump assembly is bad. It is allowing the gas to drain back into the tank. You can add a check valve in the gas line or just replace the fuel pump.
Old May 19, 2023 | 8:01 AM
My last visit at the service was with this ,the mechanic checked the fuel pressure ,he changed the fuel hose and he said that its not loosing any fuel...It was our guess also,and he also said that the spark plugs are OK,my battery is new,my injectors are renewed (cleaned) I don't know ...:-( I already spent 1300 euro
Old May 19, 2023 | 2:16 PM
The fuel pressure will be good when it is running. It's when it sits that the gas drains back into the gas tank then it has to refill the lines to get the pressure high enough to start..
Old May 20, 2023 | 12:17 AM
That's make sense!Thank you.I will go to another mechanic to explain this probability.I will come back wit a review
Old Feb 19, 2025 | 4:40 AM
FrancoPh's Avatar
Hi there i am having the same issue as yours, any update with your issue if it is resolved and kindly share how it was resolved. Thanks
Michaelprestonbishop@gmail.com
2007 - 2013 (GMT900)
Nov 9, 2022 10:58 AM
OGKaren
Sep 5, 2021 1:22 AM
BluMustard
Dec 26, 2020 12:56 PM
Turkey Track
Jan 12, 2009 7:51 AM
davemec
Aug 7, 2007 11:50 PM
