Captiva The Captiva has been sold worldwide since 2006 and now comes to the US to replace the Saturn Vue
Chevy Captiva
Platform: Theta
LH turn signals inop. front and rear.
Old Jan 26, 2019 | 11:05 AM
Jeg2941's Avatar
Default LH turn signals inop. front and rear.
My 2014 Captiva, LH turn signals front and rear inop. I replaced both bulbs since LH indicator on dash did not flash rapidly like when one bulb burnt. Emergency lights work front and back both sides, I have also replaced turn signal/headlight flash arm on steering column. Fuses checked good and still replaced turn signal fuse. I am lost, any help?
Last edited by Jeg2941; Jan 26, 2019 at 11:11 AM. Reason: added fuse check and changed.
Old Jan 30, 2019 | 1:27 PM
trillobite's Avatar
Phew... man, I am not sure. I have a shop manual for my 2015, maybe a wiring diagram for the front signals may help?
Old Jan 30, 2019 | 1:39 PM
trillobite's Avatar
My guess by looking at the diagram, the issue is between the Body Control Module, and X3 wire #30. I don't have much knowledge in understanding how the turn signals operate on modern cars, so I hope someone else can chime in with more knowledge.
Old Jan 30, 2019 | 2:54 PM
broken wire / loose connection?
Use a DMM or bulb to test continuity. Don't forget to check grounds too.
