Platform: J-body
02 chevy cavalier
Old Nov 21, 2021 | 11:04 PM
dan123456789's Avatar
Default 02 chevy cavalier
02 chevy cavalier I've replaced the whole ignition system and I'm still getting code p0304 and it's not a cracked head or head gasket I'm stumped cause it runs s and drives pretty good help
Old Nov 22, 2021 | 12:04 AM
oilcanhenry's Avatar
The Chevrolet Cavalier was a great sub-compact. I know as I owned two and Chevy built it for 23 years. You might want to compression test it, but I'll wager it is these cuases:
P0304 CHEVROLET code possible causes
  • Faulty spark plug 4
  • Clogged or faulty fuel injector 4
  • Faulty ignition coil 4
  • Fuel injector 4 harness is open or shorted
  • Fuel injector 4 circuit poor electrical connection
  • Ignition coil 4 harness is open or shorted
  • Ignition coil 4 circuit poor electrical connection
  • Insufficient cylinder 4 compression
  • Incorrect fuel pressure
  • Intake air leak
  • ECM is defective
Also you may have too much carbon on your valves. Might want to drop some Techron Complete in your fuel tank.
I did have to replace the coil pack, after recieving the dreaded P0300 code on one of my 2.2 liter Cavaliers.Easy fix.
i
Old Nov 22, 2021 | 9:55 AM
did you check for spark on cylinder 4. Spark testers are $10 this should be the first step.
check #4 injector for fuel leak at the electrical connector. If dry, you are good. run the vehicle and listen to the injector with a mechanics stethoscope,....you should hear it click as it opens and closes.
next step is to do a compression check. if compression is ok....replace the injector
Old Mar 31, 2024 | 10:27 AM
ewr's Avatar
ewr
Hi maybe my experince may help, Had a 2006 S10 with six cyl.. No 1 cyl would go to miss fire after milisec of running. Replace plugs and wires. Put a scope into
plug hole and found hardend deposits on the intake valve.. After many intake, valve chemcial cleaning finally broke the deposits away and valve seated.
Cayugaa10
Sep 9, 2015 9:51 PM
beta03
Oct 12, 2014 1:20 PM
cat11
May 12, 2014 9:54 PM
