Platform: J-body
05 Cav Burning Oil (pics)
Old Sep 21, 2010 | 7:41 PM
mlapaglia's Avatar
Default 05 Cav Burning Oil (pics)
I've got a 2005 Cavalier with 126k miles. I'm currently at the beginning of a Auto-RX treatment to help with the gunk buildup
I'm seeing quite a lot of oil in my air intake, coming from the breather tube connected to the valve cover. I removed the valve cover to find the above picture. I've since cleaned the entire cover:
and installed new gaskets, but oil is still coming out of the breather. I believe it has an oil separator built into the valve cover, but I can't get at it from either side of the cover. Is there a way to clean it out or replace whatever is inside of it? Here's a before-after of the valves
The car runs like a champ, no misfires, weird noises, or anything. I put 5 quarts in it last weekend, drove ~500 miles, and I drained it this weekend and only pulled out 3.5 quarts.. Obviously I'm in need of assistance, and any offered would be greatly appreciated!
Old Oct 2, 2010 | 7:40 PM
Segfault's Avatar
Worn piston rings, my 2¢.
Old Nov 4, 2010 | 7:16 PM
timtim2008's Avatar
hows the RX treatment going?
how did you clean out the heads? toothbrush? vac? how did you get the small stuff, that tried to fall down out?
thanks
Old Aug 25, 2011 | 12:14 AM
spedaleden's Avatar
Someone didn't change the oil like they should of. I'm sure the bottom half of the motor doesn't look good. Once the engine starts burning oil the rings are shot, only fix is to replace them.
Old Aug 26, 2011 | 3:17 PM
mlapaglia's Avatar
I posted a bunch of pictures a few days ago but I don't think the thread was approved or something. TL;DR oil control rings fixed the problem.
Cavalier Tear Down - Imgur
Old Aug 26, 2011 | 3:35 PM
kevinkpk's Avatar
As what was posted ALOT earlier, worn piston rings. I'd say alot of blowby, did you change the pcv valve?
Old Aug 26, 2011 | 4:33 PM
mlapaglia's Avatar
2.2 ecotec doesn't have a pcv valve does it? Forgot to mention I have about 6k on it since I replaced the rings and no oil burned
Old May 31, 2014 | 8:13 AM
MissNancy's Avatar
New User
Awaiting E-mail Confirmation
No such word as, alot.
Old May 31, 2014 | 8:46 AM
Segfault's Avatar
When some word is used alot it becomes a word.
Old May 31, 2014 | 8:04 PM
thanks for waking up that 3year old post to correct that. Now it can RIP. fyi, Alot is a word... a palace/town in the Ratlam district of Madhya Pradesh, India.
His diagnosis is correct also. So much blowby the pcv system can't handle it.
Duramax742
Jul 15, 2010 2:11 PM
opie4487
Oct 12, 2007 4:37 PM
Hardin Thicke
Feb 27, 2007 2:44 PM
trbball44
Sep 25, 2006 6:53 PM
