Platform: J-body
05 cavalier misfire PO303
Old Jan 27, 2010 | 8:34 PM
plink56's Avatar
Default 05 cavalier misfire PO303
Shortly after filling up at a station I don't usually go to, the car started misfiring, off and on. Showed a code PO303. I changed plugs, fuel filter, dry gas, injector cleaner, and also swapped a different coil/Ign mod. All of the above made no difference. I then changed oil and filter and after a few miles it started running fine again. Around 50 miles later it started missing again. A chevy mechanic looked at it and said it was a stuck valve, and the 2.2 ecotecs are noted for that. I kinda suspected an exhaust valve anyway. Does anyone know of any good additives that will clean the guides/ stems, I don't think its bent because of the sporadic nature of it clearing up for a while.
Thanks in advance.
buddyleno
Mar 31, 2017 8:13 AM
perry2326
Oct 19, 2013 10:25 PM
moaabyss
Apr 30, 2013 8:47 PM
Biggumzmcgee
Nov 15, 2009 10:51 AM
atomheartmother
Jun 29, 2008 9:41 AM
