Platform: J-body
1990 Cavalier Z24 - won't fire
Old May 22, 2008 | 8:12 PM
bluezmom's Avatar
Default 1990 Cavalier Z24 - won't fire
We have a 1990 Cavalier Z24. Daughter was driving home from school (maybe 3 miles) and the car died and wouldn't start back up. When I got to the car and got in, I could smell burnt or melted wire or plastic inside the car - not outside or under the hood. I checked all the fuses, loosened the panel under the dash and checked wires / connections, and found nothing wrong. The fuel pump works - I can hear it, but it doesn't seem to be getting any fuel - I can't smell any when trying to start it even if I hold the pedal down. What's next to check? Am I guessing right that the ignition switch would be the next likely culprit? How much of a hassle is that? Thanks for any input ....
Old May 23, 2008 | 1:23 PM
shawnvw's Avatar
Banned
Default RE: 1990 Cavalier Z24 - won't fire
the next step would be to check if the engine is getting spark, check fuel pressure, and to see if the injectors are firing
Old May 24, 2008 | 8:51 AM
bluezmom's Avatar
Something I should add here as this might help diagnose the problem a little easier - my daughter said she "smelled something burning" before the car died, and then just a few seconds later, it died.
Rltkktlr
Feb 16, 2014 9:37 AM
SDFoster22
Dec 16, 2013 6:15 PM
perry2326
Oct 19, 2013 10:25 PM
freakville03
Mar 29, 2012 5:59 AM
pissonadodge
May 23, 2007 7:35 PM
