Platform: J-body
1995 Chevy Cave wont start
Old Jan 18, 2020 | 2:13 PM
Rick Rinear's Avatar
Default 1995 Chevy Cave wont start
This has gone on for two months, change fuel filter, no diff...replaced the fuel pump relay (in fuse box) started rite up and ran ok for about 50 miles then no start again. Will run if pour bit of gas in throttle body then coughs and dies. Autotranny and everything else works ok!! what gives? thx
Old Jan 18, 2020 | 2:18 PM
kevinkpk's Avatar
Right off the top my guess is fuel pump.
Old Jan 18, 2020 | 3:03 PM
Could , heck of a job changing tho if not the prob. The relay makes it work for a few miles...strange, eh? Could it be pressure regulator?
Old Jan 18, 2020 | 3:37 PM
kevinkpk's Avatar
Check fuel pressure when it won't start, also it is quite possible fuel pump intermittent or restriction. Since you've replace the filter, could be bad gas. Coincidental as the fuel pump may be just on the verge of supplying enough pressure at times.
Old Jan 18, 2020 | 3:45 PM
Thx will check this out, gas is new, filled up as soon as we put fuel pump relay in and it started
David3954
Jan 21, 2023 5:55 PM
steve_bl
Nov 7, 2022 10:46 PM
Cory Balthazar
Nov 22, 2015 7:26 PM
Rca1965
Jul 2, 2007 7:55 PM
Enstar
13
Jun 22, 2007 10:36 PM
