Platform: J-body
1996 cavalier theft light on no start
Old Jan 18, 2010 | 7:06 PM
hoghollow's Avatar
Default 1996 cavalier theft light on no start
1996 cavalier theft light is on not flashing but stays on. Car will not start have already changed fuel pump because the pump did not run when key was turned on. We did not notice the anti theft light being on. New pump does not run either. Have left key on for up to half hour light will not go out or blink. Any ideas or help thanks
Old Jan 19, 2010 | 12:31 AM
todds96cav's Avatar
Have you checked all your fuses and relays? Maybe unhook your battery overnight and see if it resets the anti theft device.
Old Mar 6, 2010 | 5:07 PM
vortec02's Avatar
think i may be having the same problem on my 99 z24. theft light on and no power to the fuel pump, or the fuel pump relay. just one thing i have that you may have left out. when you turn the key to the on position, does the check engine light stay on like it should? mine doesnt. if you found your problem, could you let me know what it was.
Old Nov 10, 2011 | 10:18 AM
dagreyon's Avatar
Default 1996 cavalier theft light O.o
I replaced my illuminator I believe thats what its called...It shows the temp speed rpm gas levels. Well i replaced mines because i wanted 1 with rpms once i replaced it my theft light came on currently i have the battery unhooked and when i get home from work ill hook it back up but im pretty sure it will still be there O.o how do i get that stupid theft light off so i can drive again >_<
Old Nov 10, 2011 | 11:45 AM
kevinkpk's Avatar
Yes. If the anti-theft fuse is open, blown, it will not start. The fuel pump won't come on with anti-theft on. What has changed? You might try turn on the key switch for about 10 minutes, then off, then try to start it.
Old Nov 11, 2011 | 9:56 PM
binzer's Avatar
I believe you mean your instrument cluster.
Take a look at this link for instructions as to how to get your theft system to relearn...
FAQ - j-body.org - the jbody organization
dsab
Oct 28, 2014 3:19 PM
Thollon
May 29, 2013 1:38 AM
slim53
Apr 19, 2011 12:05 PM
