Platform: J-body
2000 Chevy Cavalier Running a little hot
Old Oct 25, 2013 | 7:46 PM
CaliChuck's Avatar
Default 2000 Chevy Cavalier Running a little hot
Its a 2.2 Engine Automatic if that matters.
It will drive fine but if I drive it for more than half an hour it heats a little. I check the radiator fan and it doesn't spin so Im wondering if it kicks in at a certain temp(it should if its running hot). If my sensors are messed up or if its the radiator fan itself. Im buying a code scanner soon but until then, what do you guys think the problem could be?
Old Oct 25, 2013 | 9:24 PM
What do you mean by heats a little? Is it overheating? The code scanner will only work if the check engine light is on. The fan only comes on when engine reaches a specified temperature.
TahoeMatt
Oct 15, 2014 4:10 PM
cryptonight
Aug 18, 2013 2:25 PM
EnyChevyUK
Aug 25, 2010 2:59 PM
atomheartmother
Jun 29, 2008 9:41 AM
