Platform: J-body
2000, Z24, with issues, HELP
Old Nov 19, 2011 | 3:28 PM
freakville03's Avatar
Default 2000, Z24, with issues, HELP
Daughter went to McDonald's and parked the car. Came out and put it in Reverse, then in Drive, but when she put it in drive it kept going in reverse. So she put it in 3 and the car was able to go, and she pulled it back in to the parking spot. When she put it in park the car kept going forward like the car was in neutral. she called me I went there and no matter what position you put the stick it's like the car is in neutral. Was wondering if anyone has had this issue. Also the TRAC OFF light was on as well.
Old Nov 19, 2011 | 4:26 PM
EinST's Avatar
Welcome to the forum. The shift cable may have come undone. The cable goes between the shifter assembly in the center console and shift actuator on the transaxle.
Old Nov 19, 2011 | 5:01 PM
is that shift cable pretty hard to get too?
Old Nov 19, 2011 | 5:37 PM
EinST's Avatar
It's hard to tell. The center console is held in place with screws. There's usually a hidden screw or two as well. On the transaxle end, the shift actuator is on the driver side. You may need to remove the air cleaner duct. Once you get there, recognizing what and how something is broken is another matter.
perry2326
Oct 19, 2013 10:25 PM
Don Meadows
Oct 4, 2013 12:32 PM
Fixxxer
Feb 16, 2008 5:13 PM
omarr72
Jun 18, 2006 5:52 PM
