Platform: J-body
2002 Cavalier jerks when braking
Old Jun 27, 2011 | 3:47 PM
earlywins32's Avatar
Default 2002 Cavalier jerks when braking
Hi i have a 2002 cavalier and it has just started jerking when i brake. It does it in both reverse and drive. It only does it for the first few times then it brakes just fine. Any ideas what is wrong?
Old Jun 29, 2011 | 11:47 AM
MyBowTieGuy's Avatar
earlywins,
Does your Cavalier also buck or pulsate occasionally under braking? From the symptom that you described it sounds like your rotors may be warped. Take your car to a reputable brake shop and have a skilled mechanic resurface them and the jerking phenomenon that you described should disappear. If not, then the rotors may have to be replaced. If you're on a strict budget (and who isn't these days? ) conduct a search online for inexpensive OEM Cavalier rotors and you'll get lots of results. I believe that gmpartsgiant.com is a solid discounted OEM parts outfit.
Keep us updated on the situation man
desertdawg70
Nov 13, 2020 4:12 AM
eweeks1
Apr 23, 2014 6:46 PM
hokans
Aug 10, 2010 5:31 PM
monte99
Mar 18, 2010 8:29 PM
cperkins21
Oct 1, 2009 7:38 AM
