Platform: J-body
2002 Cavalier rear defrost problems
Old Jan 11, 2007 | 2:45 AM
coling659's Avatar
Default 2002 Cavalier rear defrost problems
I have a 2002 cavalier that the rear defrost has suddenly stopped working. The light comes on inside the car to indicate that it is on but it does not appear to work. I have checked the fuse and it was not blown. Any help with this is needed.....Thanks
Old Jan 11, 2007 | 6:37 PM
beckeruti's Avatar
Default RE: 2002 Cavalier rear defrost problems
check the connections at the back winodw to make sure they are plugged in all the way and dont have corrosion on them
if u have a volt meter check for power at them also
u will only get power to one side
the other side is ground
not sure which is which tho
Old Dec 8, 2011 | 8:26 AM
danker's Avatar
It may also be a burned out connection in the harness from the front to the rear. Check under the dash near the hood release and there will be connection point of a few harnesses. If it is burned out the plastic connectors will be black and/or burned and melted. I have had this happen on 2 of my cavaliers. I just cut free from the wires from each side of the harness (melted together) and added a jumper wire the same gauge.
Old Oct 14, 2013 | 9:17 PM
pooparew's Avatar
New User
Awaiting E-mail Confirmation
Default danker was right
ive been smelling a burnt plastic smell only when the rear defroster was on for a few weeks. after reading the forum i found that dankers answer to the problem was the same as mine... gees thanks i was going to tear out the entire dash looking for the problem. i found that the burn connecter was just under the carpet on the drivers side next to the hood latch, and holly fire haserd batman it had dripped melted plastic all over the place and left a big hole in the connecter.
Dbuseyiii
Sep 20, 2021 9:26 AM
April81
Aug 5, 2013 9:41 AM
McSilvio
Jun 13, 2012 1:29 PM
thenaes
Dec 2, 2011 7:59 AM
district2453
Feb 16, 2010 11:36 PM
