Platform: J-body
2004-Gas In Air Intake
Old Jun 15, 2010 | 2:01 PM
Ken D's Avatar
Default 2004-Gas In Air Intake
I have an 04 Cav. with a fuel/air issue.
Was having problem with car dying and running badly,
but would run fine at highway speeds.
Then next day, no prob., but once driven has same thing.
Had a split gas cap, replaced.
Removed air pipe from filter/to manifold and found
over a quart of gasoline in the tube.
No evidence of outside influences
( ie: dirt/residue from intake or injectors, leaks anywhere, etc. )
Air filter itself is totally clean,
not even a smell of gas in it.
Would a crankcase ventilation problem cause this?
Maybe the fuel pressure regulator??
Any help would be appreciated!
Thanks
ps: does this thing even have a pcv valve??
Old Jun 28, 2010 | 2:48 PM
Richboy1969's Avatar
I've got a similar problem, Mine is oil in air tube. Mine doesn't have PVC valve. On the 2.2L it is built into the valve cover. I'm replacing the valve cover and will let you know if that fixes it. I was told that the drain ports in valve cover were stopped up.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Jul 6, 2010 | 11:43 AM
Duckman33's Avatar
Originally Posted by Richboy1969
I've got a similar problem, Mine is oil in air tube. Mine doesn't have PVC valve. On the 2.2L it is built into the valve cover. I'm replacing the valve cover and will let you know if that fixes it. I was told that the drain ports in valve cover were stopped up.fficeffice" /><o>></o>>
I have the same thing on my '03 Cav. Would be nice to know if replacing the cover fixed it.
Old Jul 7, 2010 | 3:46 AM
As soon as I get it and get it on I will update with the results. I ordered a new one from Lake Chevrolet and haven't received it yet.
Old Jul 8, 2010 | 9:11 AM
Duckman33's Avatar
Sweet. Thanks Rich!
Old Jul 12, 2010 | 8:54 AM
That was the problem. I put it on a few days ago and check it this morning and there was no oil in the air intake. My car has alot of blow-by and i'm wondering if that is normal. It's only got 98,000 miles on it. There was alot of what I call oil varnish inside the cover. Crud on the front side. Hope this answeres somebody elses question.
Last edited by Richboy1969; Jul 12, 2010 at 9:03 AM. Reason: Clairfy where oil had been.
Old Jul 13, 2010 | 9:30 AM
Duckman33's Avatar
Thanks man.
Guess I know what I'll be doing soon. I was wondering if I might have pad a blown head gasket because of the oil. But no smoke out the tail pipe and no overheating. Compression test passed too. One other thing I see if a creamy colored froth on the dipstick, but I'm told that's normal with these cars.
Anyway, thanks again for the follow up Rich, very much appreciated!!
Old Jul 4, 2016 | 7:23 PM
angelfish's Avatar
Default Solution?
I can see that there is a solution posted for the one who had oil in the air intake...but what about the problem of fuel in the air intake?
I have the fuel problem. The car just stopped starting. It tries to fire up, but won't turn over. We did notice today that there is a lot of fuel in the air intake. There are 2 hoses, one that runs to the fuel injector and one that goes to the air intake. Fuel is coming out of both hoses. We did have a used fuel pump put in (after the car stopped starting) by a different mechanic (we are wondering if he reversed the hoses coming out of the fuel pump?) and today we replaced the air intake (the black box that is in front of the injectors). It was then we noticed the fuel in the air intake. The original one had a loose hose at the back and it broke off today (wondering if that was the problem of it originally not starting anymore?) so it needed replacing, however this did not fix the problem of not starting. Any ideas would be appreciated!
Old Sep 16, 2017 | 3:26 PM
Lorin Peck's Avatar
Smile Had problem, fied
My wifes Ford Taurus did the same thing. Diapham broke squirting gas into vacuum line. Had to hold pedal to floor to unflood to start. Yes that trick still works, tells computer to shut down fuel. Anyway took vacuum line off FP Sensor. full of fuel.
ahearnm
Mar 19, 2023 6:37 PM
caddieb
May 15, 2011 5:32 PM
Mille Racer 69
17
Nov 7, 2010 4:19 PM
