Platform: J-body
2005 Cavalier horn issue
Old Dec 27, 2021 | 12:14 AM
andrew.horton89's Avatar
Default 2005 Cavalier horn issue
Hello,
I just bought a 2005 Cavalier from a private seller last month, and the headlight/turn signal switch didn't function properly. I replaced it with a switch from a Pontiac Sunfire, and now my headlights and signals work correctly again, but now the horn doesn't work. Has anyone had this problem before? I've checked some of the wiring, but not all of it. I was wondering if anyone knew of this being an issue on this particular car and had any suggestions. Any recommendations would be greatly appreciated. Thanks!
Old Dec 27, 2021 | 8:16 AM
Welcome from Florida. Double check what you did as it sounds like when you were in there, you might have disconnected the horn wire by accident.
Old Dec 27, 2021 | 9:05 AM
Thanks. (: Where exactly is the horn wire located? I really know nothing about this car so far.
Old Dec 27, 2021 | 10:25 AM
In the steering column under the horn button.
Old Dec 27, 2021 | 1:09 PM
I'll give that a try on my day off tomorrow. While I'm at it, I have another question you might be able to help me with. How do you get that damn covering off from around the tilt handle without breaking it?
Old Dec 27, 2021 | 5:12 PM
I don't know much about the Cavalier. Just be careful with the air bag.
Old Jan 5, 2022 | 6:19 AM
So I tried to look for that horn wiring and I couldn't directly find it. I have a Haynes manual I looked in and it wasn't much help. Does anyone else here possibly know exactly where that connection is? I tried asking on a J body forum, but it doesn't appear to really be very active. I've had far better responses here. Thanks to anyone who can give me any advice.
Old May 26, 2022 | 4:38 AM
David van duzen's Avatar
Originally Posted by andrew.horton89
Hello,
Did you change the relay too? I had same problem. Also check fuse inside drivers door 10 Amp. Might try change that also check make sure whole box is secure. Good luck park mine in garage and problem stopped
Sound like moisture shorting. But yea have to change relay when change switch.
Old May 28, 2022 | 3:31 AM
Had same. have to change relay but as mentioned watch airbag. I park mine in garage and same ting it stopped. Sounds like moisture also make sue grease the switch. Relay is in column where you changed switch. Hope helps.
KM4363
Apr 18, 2017 6:55 AM
gage3780
Oct 28, 2015 10:59 PM
Letty Rosales
Nov 25, 2012 5:39 PM
mrbill
Jul 6, 2008 6:34 PM
sillyjay1975
Dec 26, 2007 9:37 PM
