Platform: J-body
'92 Z24 cavy intermittent missing/running rough
Old Apr 7, 2013 | 7:29 PM
JoeyWV's Avatar
Default '92 Z24 cavy intermittent missing/running rough
So off and on my car misses really bad. Spark plugs are only a couple months old, pulled and check them yesterday, they're fine. Pulled the coil packs and cleaned them up real good, still missing, bought new spark plug wires, still missing.
before i bought the wires, I would pull one wire at a time and stuck another spark plug in it and started the car to double check that they were all getting spark, which they are, but when I finished it ran normal but with a couple misses here and there. So I figured the wires were shot and that's why I bought a new set.
I also gave it an oil change and put Lucas Oil Stabilizer in it, because it was long over due for a change anyway. The car has just about 210,000 miles on it and this is the first hiccup I've ran into since I bought the car.
ran my OBD I for GM on it and it only pulled code 12, which from what I understand is just a default code to say the diagnostic system is working correctly.
A friend told me possibly an O2 sensor could cause it to run like that, but I don't want to keep buying parts that wont fix the problem. Anyone know whats going on with this thing?
Old Apr 16, 2013 | 11:39 PM
go-part's Avatar
Former Sponsor
How to Test an O2 Sensor | eHow.com
Test the 02 sensor, it can be the cause of a misfire condition due to it giving wrong feedback to the ecu and that will cause the engine to run rough
macmommy
Apr 22, 2020 1:23 PM
perry2326
Oct 19, 2013 10:25 PM
Steven Gillespie
Aug 28, 2013 10:35 PM
87 silverado
Oct 24, 2008 1:21 AM
matt_p
Mar 3, 2007 5:43 PM
