Platform: J-body
93 cavilier wont blow any air
Old Aug 22, 2006 | 7:16 PM
andrew.riedl's Avatar
Default 93 cavilier wont blow any air
I recently bought a 93 cavilier to run back and forth to work in. My problem is the fan motor runs but there isnt any air coming out. I think that there must be a blockage someware, but where should i look?
Old Aug 22, 2006 | 10:05 PM
kcb37's Avatar
Default RE: 93 cavilier wont blow any air
If your fan isn't hard to get to it may be easier to take the fan out and see if the blades are turning. Just hold it kinda tight and trun it on low first.
Old Aug 25, 2006 | 3:16 PM
TateC's Avatar
I have same problem with our 93 cav. Blower Sounds like it picks up speed on all 4 setings. Air will change from floor to dash to defrost. But there is very little air from any vent. I pulled the blower out and the fan looks fine, I didn't think to run it while it was out. Nothing blocking the hole blower fits in. Is there a filter some where in the heater box? T.C.
Old Aug 25, 2006 | 6:43 PM
kcb37's Avatar
Their may be but I think it would be where the blower is pulling air from to put thru the vents.
Old Aug 25, 2006 | 9:06 PM
beckeruti's Avatar
probably a vac line
vacuum from the engine opens and closes the mode doors
check under the hood for anyloose vac lines first then look under the dash
it might be the actual sloenoid tho
good luck
if u live newar phoenixville
i will look at it for u for free
Old Aug 26, 2006 | 12:14 PM
TateC's Avatar
I think beckeruti is probably right about the vaccum poblem. Thats what I will be checking next. I wish I could find a diagram of the vac system. Could be hard to figure out with out taking to the dealer. I'll let you know if I find Something. T.C.
Old Aug 26, 2006 | 1:26 PM
beckeruti's Avatar
if u can wait till monday when i go to school i can look it up on alldata
and email it to you
Old Aug 26, 2006 | 2:28 PM
TateC's Avatar
Thanks beckeruti, any help would be great. T.C.
Old Jul 14, 2010 | 12:36 AM
dnorthover's Avatar
If this is anything like the 92 Cav> I had a similar problem and it turned out that the Evaporator coil fins (in the fire wall behind the engine just below the wiper motor) was totally blocked with dirt thus preventing air flow. try removing the fan shroud from the firewall and check Evap coil for blockage. A large wire brush will work just fine to clean it up. Good luck
Blaidd Drwg
Nov 19, 2013 3:49 PM
dad
Jun 2, 2008 9:32 PM
ruffrider285
Mar 17, 2007 10:58 AM
