The wipers started stopping while in use so replace the motor and the pulse board. Also purchased a used wiper switch but now I have nothing. The fuse is good and I have power on the white wire to the motor and the switch. Whats crazy is when I turn the wipers to high, the wiper motor does not come on at all but it starts pumping washer fluid out. Not sure where to go next. Thanks for any help.
Here is a pic of what I assume is the ground strap. I put a washer on the bolt just to make sure there was plenty of metal to metal contact. Looking at the wiring diagram this is the only ground? Please correct me if I am wrong.
Well today after securing that ground better, now when I turn the wipers to high nothing happens. It does make a clicking sound when I turn it off or on, but no sound when I switch to low or high, so really not sure now LOL. Thanks
I used my test light on the switch and the White wire is hot all times. The PPL wire is 10v when the switch is on high, and the Grey wire is 5v when on slow. No matter how I move the switch i cannot get any voltage out of the Pink or Orange wires.
If it was something with the motor wonder why the washer fluid pump is not working at all.
I used my test light and I have power on the PPL wire and the Grey wire at the motor. I swapped the old pulse board back in just searching for answers and it did nothing.
Also I do not have the wiper arms connected yet wanted to see if the motor would turn itself first.
