95 Cav 2.2 no start
This is neigbers car, 95 Cav 2.2L Auto 2door.
They bought this car not knowing that it was flood damaged, seller never said anything. When they had title switched they found out.
It was running, but the tranny wasn't shifting properly so they switched the VSS on it, without disconnecting the battery. Ever since then the car will turn over just fine but will not start.
Then they got a used PCM and installed, but I don't think they changed the EPROM. No spark or injector pulse.
Do the 95's have a passlock system that needs a relearn procedure and if so what would it be?? I have found passlock procedure for the 96 and newer.
Thanks for any advice and input.
cc2001
Apr 20, 2008 9:43 AM
gargamel343
Mar 14, 2007 12:58 PM
