Platform: J-body
96 cavalier reinstallin fuel hose
Old Aug 23, 2012 | 10:05 AM
tjokerst91's Avatar
Default 96 cavalier reinstallin fuel hose
I have a 96 cavalier that had a gas leak. I was able to find the
leak it was at the top of a hose going into a metal line(in the
front near the motor not near the tank or fuel filter). I cut off
the bad off the rubber hose and got the hose back into the
conection but when i tryed starting it the hose just blew
right out due to the gas pressure. I cant find out if i need a
special hose that will lock into the metal conection or some
kind of adapter I have looked all over the internet an been
to a few auto store an no luck so far. Any help is greatly appreciated
Old Aug 23, 2012 | 12:54 PM
kevinkpk's Avatar
Put a hose clamp on it.
Old Aug 23, 2012 | 4:19 PM
tjokerst91's Avatar
the metal conection that the hose goes into is round an gradually gets wider also iwas thinking i may need an o ring or something to keep gas from leaking out
Old Aug 24, 2012 | 7:53 AM
If the hose is old and it has already failed, replace it. Get new hose and make sure it is rated for fuel injected cars and use hose clamps on both ends.
Old Aug 28, 2012 | 10:29 AM
tjokerst91's Avatar
ive looked at new hoses an they have nothing to connect into the metal fuel fed line and a hose clamp wont work because the metal line is wider then the hose.
tbb2
21
Jan 1, 2021 10:01 AM
farmy87
Jan 23, 2013 8:08 AM
RelicAte
Jul 7, 2012 11:15 AM
jpatterson6136
Nov 19, 2011 10:40 AM
2000Impalaspeeder
Jan 31, 2011 2:13 PM
