Platform: J-body
99 Cavalier 2.2L Upper hose feels like a ballon with air
Old Jan 25, 2011 | 12:05 AM
2000Impalaspeeder's Avatar
Unhappy 99 Cavalier 2.2L Upper hose feels like a ballon with air
I had installed a new water pump and thermostat,
filled up the reservoir with 50/50 coolant & water
bleed the coolant system but I think there is still air
because when the engine is running & hot the Upper hose
feels like a ballon with air inside idk if maybe there is air still
or i didnt do somthing right.. can someone help me????
Old Jan 29, 2011 | 1:47 AM
2wd-K5's Avatar
did your install the thermostat backwards? this could cause the coolant no to circulate, but then your car would overheat too
Old Jan 31, 2011 | 2:13 PM
no, I didnt install the thermostat backwards.. I didnt remove all the
air.
I ended draining the the coolant, and removing the vent bleeder screw,
& add the coolant back..as I watched at the vent bleeder hole coolant was dripping, I closed the bleeder screw.. since then the new upper hose
doesnt feel as if it was a ballon with air.
arm&wrench1088
Dec 24, 2010 6:38 AM
crwalker2
May 8, 2010 10:01 AM
Impowa
Mar 23, 2010 8:35 PM
vbob2
Aug 2, 2007 1:16 PM
HeavyChevy
Oct 13, 2006 3:17 AM
