Platform: J-body
97 Cavalier ABS/parking brake lights on
Old Feb 25, 2012 | 11:28 AM
mikebruce700000's Avatar
Default 97 Cavalier ABS/parking brake lights on
I just bought a 97 Cavalier. The ABS and parking brakes lights are on and the rear brakes lock up. The previous owners lived down a long dirt road, which kept the bottom of the car muddy/dusty. Any ideas on where I can start? The wheel drums and pads look decent. THANKS!
Old Feb 25, 2012 | 2:22 PM
cleveland63b's Avatar
check brake fluid and pull the drums, might have wheel cylinders leaking
Old Feb 25, 2012 | 4:23 PM
Thanks! Just replaced the rear shoes (one was a little worn, but not horrible). Rear brakes are not bad anymore, but the lights are still on. No leaks, fluid is good.
Old Feb 25, 2012 | 5:43 PM
EinST's Avatar
The ABS warning indicator can be due to the BRAKE warning indicator being on in which case the brake fluid level switch may be malfunctioning. Disconnect the electrical connector from the brake fluid reservoir and see what the BRAKE warning indicator does with key on. Then, carefully jumper the circuit by shorting the two wires (thin paper clip inserted into the electrical connector will do) and see what the indicator does with key on.
kaptain howdie
Dec 16, 2014 8:20 PM
Hectorson3
Sep 13, 2014 12:22 PM
christinam091502
Jan 9, 2013 8:06 AM
fire165
Feb 4, 2011 10:36 PM
