Platform: J-body
97 cavalier horn stuck on
Old Dec 16, 2006 | 2:10 PM
grail's Avatar
Default 97 cavalier horn stuck on
Anyone have a suggestion?I was told it was probably the relay - does that sound right or does the steering column have to be taken apart?
Thanks
Old Dec 16, 2006 | 5:15 PM
bk94si's Avatar
Default RE: 97 cavalier horn stuck on
The relays are usually under the hood. Look for a black plastic box and when you take off the cover, all the relays are inside. There should also bea diagramshowing which one goes to the horn.
Old Dec 16, 2006 | 6:46 PM
grail's Avatar
Thanks
Old Dec 16, 2006 | 11:09 PM
beckeruti's Avatar
a 97 the relays should be under hood driver just behind battery
good luck
Old Dec 17, 2006 | 10:10 PM
grail's Avatar
The horn relay is under the dash on the passenger side. Unscrew the panel and look up for, in my case, a white relay switch.
Old Dec 17, 2006 | 10:27 PM
bowtiez's Avatar
My friends son's 99 z24 did the same and it turned out to be the contact on the ring in the column.
Bill
Gmc25oo
Nov 15, 2014 11:29 AM
BigblackHo3
Apr 5, 2013 8:54 AM
fender177
Feb 11, 2008 6:32 PM
isaac_22
Dec 26, 2007 9:23 PM
zulu
Mar 28, 2007 4:58 AM
