97' -- Dashboard Light
Small light on the left hand side of the dashboard.
It's red and it looks like a box, with an arrow pointing down to a squiggly line of what appears to be liquid.
I don't have the owner's manual when I bought it from the dealership. I'm not sure what the problem is.
Any ideas? I've checked the transmission, oil, steering, windshield liquid, and coolant and everything appears to be in good condition.
i had that problem on my 96... if i was you check the water pump and check the lower raditor hose... i had a leak coming from the pump and the hose you can get the part kinda cheap.. but just double check before you go and spend a s**t ton of money when you dont have to
