99Z24 wont start
hey guys new to this forum been on another forum for a while and just came across this one. ( this is a copy of my tread from the other forum) so heres the deal i have a 99 z24 2.4l 4speed auto. battery has been in and out and finally bit the dust. got a new battery for it, and it wouldnt stay running. then it wouldnt start at all. i pulled it home with our blazer, got it home . i figured it had something to do with the theft system. the theft light would stay on. eventually it went off and it started and had it running for about 2 mins. then all of a sudden it just died. no spit no sputter just complete loss of power! just like i turned the key off. ive had electrical problems in the past with this car, and unfortunatly no codes due to the battery being disconected. i did notice when the theft light is on, (key on not running) the check engine light is off i can here something intermittenly getting power and the check engine light flickers when this is happening. when the light stays on, the theft light goes out and it will start but immediatly stall. it seems to me like a loose wire somewhere just dont know where i should look. heres a list of things that have been replaced in the past:
new computer, used engine, new alternator, new starter, new plugs,wires,coilpacks, new cam sensor, anything else i should be looking at if the theft system is causing this is there a rest procedure? PLEASE HELP!!!! having one vehicle is really hard
Update since i wrote this on the other forum//// now i turn the key on, theft light still on, but now the check engine light will flicker for about 1/2 second and go ou.t tried theft system reset. leaving key on 15 mins not touching anything yadda yadda yadda, ive cleaned all grounds all power wires even took the fuse box
apart and cleaned in there. checked all fuses, all good im stumped!!! please i need help!!! thanx in advance to anyone who can help
![](http://www.automotiveforums.com/vbulletin/images/smilies/runaround.gif)
ok so just a question could this be caused by a bad ignition control moduel no power to my fuel pump or fuel pump realy and i dont think im getting spark
UPDATE
well found out its not the ignition module just put a new one in $150 bucks to find out the hard way it wasnt the problem and well coil packs and plugs n wires arent that old either man this car is just gettin on my nerves pulled the pcm and checked all the wires there wires and conectors all look clean and in tact god i hate GM right now lol so far im still puttin my money on a bad wire somewhere just cant find it and well unfortunatly no codes due o the new battery and it hasnt been running for the computer to run its cycle this sucks
sleepingciv
July 25th, 2020 1:03 PM
luvche
Cobalt
May 31st, 2014 1:44 AM
wildboy74ss
April 1st, 2009 5:10 PM
