Platform: J-body
Ac problem
Old Aug 12, 2012 | 2:09 PM
Bhoff's Avatar
Default Ac problem
Hi i have a 2002 chevy cavalier 2.2l 4 cyl. My ac works fine when coasting and idleing, as soon as you press the accelerator at all it blows out warm air. If i have the car on cruise control at any speed/engine rpm it blows warm.
Along with lurching on accelerating from a stop, in 1st gear by the time the engine rpm is reaches 3000 the engine rpms would rise and stop rise and stop approx 3 times. I figured this would occur because the car only has 120 hp and the ac draws alot of power, however the ac not working while cruise control is on is confusing. Any suggestions??
Old Aug 18, 2012 | 7:25 PM
cleveland63b's Avatar
sounds like a vacuum leak
Old Aug 18, 2012 | 7:34 PM
check engine light on? The a/c is designed to cut out at throttle positions over 80% which the pcm considers wide open throttle. Check and see if there is a tps sensor code or any dtc for that matter.
Old Aug 21, 2012 | 3:13 PM
Bhoff's Avatar
The check engine light isnt on, and when the ac is off the car performs as it should without any hiccups
Old Aug 21, 2012 | 3:38 PM
kevinkpk's Avatar
Is the cooling fan on with a/c on?
Rosariods
Jul 21, 2011 8:13 PM
BayAreaChevyGuy
Jan 6, 2011 2:27 AM
chenzo
Mar 21, 2010 5:35 PM
99silver
Feb 2, 2008 4:14 PM
Yesi
Oct 8, 2006 6:27 AM
