Platform: J-body
Aftermarket radio installed, no rear audio
Old Jan 21, 2026 | 12:35 AM
scottl631's Avatar
Default Aftermarket radio installed, no rear audio
just installed an aftermarket single din radio in my 03 cavalier. pretty sure all the wires are connected correctly. im not using a connector adapter. i had to hard wire them directly because previous owner cut it out. anyway, front speakers work, just no rear speaker action. i check the fader and balance, and the rears are very low compared to fronts. my guess is the stock amp is not turning on? the blue/white wire from aftermarket radio is not connected which should be for remote amp turn on signal. i had no place to connect it to. where does this wire go if its needed? google says it should go to a pink wire, but i dont see any pink wires back there. any suggestions?
b0ur
Sep 13, 2025 6:01 PM
noxlanding
Oct 26, 2020 5:03 PM
Thedoc2k
Jul 16, 2016 10:21 AM
an1213
Apr 23, 2015 10:11 PM
tom5170
Oct 10, 2012 12:37 PM
