Platform: J-body
been having this issue for a month and cant fix it please HELP!!!
Old Aug 17, 2011 | 3:48 PM
chevyman69's Avatar
Smile been having this issue for a month and cant fix it please HELP!!!
hi guys, i need your help on this one please, i have a 05 cavalier 2.2L. the car has an issue at the take off ( especially if i step in the gas pedal all the way, it actually turns off) it has a really slow take off but after it has gain some speed its fine. now ive change map sensor, the cat, fuel filter, tps sensor, fuel valve pressure, air control sensor, spark plugs, and the sensor that is locate in the intake pipe ( its a very small one). even the dealer told me that it was the cat and map sensor and still doing the same thing. oh, i check the alternator and its good. if any of you guys have any idea on what it can be please i would really be greatful with you guys.
Old Aug 17, 2011 | 4:01 PM
kevinkpk's Avatar
Might try cleaning the maf sensor with approved cleaner.
Old Aug 17, 2011 | 4:35 PM
chevyman69's Avatar
but i got i new sensor now. and no check engine light.
Old Aug 17, 2011 | 7:01 PM
chevyman69's Avatar
anyone else please...
Old Aug 18, 2011 | 5:50 PM
93Cavi22's Avatar
I had a similar problem with my 2.2L. I changed out most of the same things you did, but it turned out to be the fuel pump. A pain to replace, but it fixed it. Maybe a fuel pressure test is in order. Good luck!
Old Aug 19, 2011 | 10:21 AM
chevyman69's Avatar
i just did the fuel pressure test, its pushing 60 and when i press the botton on it its drops it to 30. i think thats a good pump right?
Old Aug 19, 2011 | 7:55 PM
would be nice to know some fuel trim data and injector pulse rate info
auto or manual trans?
Old Aug 21, 2011 | 9:18 AM
DHoShow's Avatar
Could be a problem with your torque convertor (in an automatic)
noonecanfixmyblazer33705
Feb 6, 2014 9:24 AM
stanman
Mar 17, 2013 6:23 PM
WhiteZ28
Camaro
Mar 18, 2010 10:09 PM
perfer chevy
Feb 18, 2008 4:18 PM
