Platform: J-body
A/C problem
Old Jun 25, 2020 | 12:13 PM
beerbuzz's Avatar
Default A/C problem
2002 with 4 cyl engine. While stopped and idling, the ac blows nice and cold. Low side line is cold and sweating good. But when i start driving it stops blowing cold air and blows not cold air. Has anyone had this problem before? I thought it may have been overcharged so i emptied the system and recharged with 24 ounces. But still the same.
Old Jun 26, 2020 | 1:40 AM
oilcanhenry's Avatar
Did you vacuum out the air? If not, that's your problem. Have to pull it down to -30 PSI for half an hour at least, to boil out any condensation as well. No atmosphere at all is allowed.
Old Jun 26, 2020 | 6:24 AM
beerbuzz's Avatar
Yes. I pulled vacuum to 29 hg. Couldnt reach 30. Vacuum held overnight. So im im convinced no moisture and no leaks. Thanks for replying. I need all the help i can get. Lol
Old Jun 27, 2020 | 12:43 AM
-29 hg converts to -14 PSI. Sorry, but we Yanks still use imperial measurements. If it held vacuum overnight that means no leaks which is good. The purpose of a vacuum is to eliminate all the air and boil out any condensation as air and moisture are not good for an A/C system, as you stated. When you are stopped, can you rev the motor up as if you are driving, and does the magnetic clutch for the A/C compressor engage at that RPM? Of course, this is with a charged system, not a vacuumed out A/C system.
Scott Lumley
Aug 6, 2017 12:29 PM
Aavronle@gmail.com
Apr 21, 2015 10:07 PM
jgray152
Jun 2, 2013 10:01 AM
lutherbeau
Camaro
Nov 8, 2012 1:55 AM
fordchevy
Aug 19, 2009 6:11 PM
