Platform: J-body
Cavalier 4t40-e Transmission
Old Dec 28, 2011 | 4:56 AM
Tooth's Avatar
Default Cavalier 4t40-e Transmission
I recently installed this transmission in My car, I had a few problems with wiring. EinST and MDTAHOE helped Me through that secnario and everything is working as it should with the exception of the transmission. When I installed this transmission I changed the front pump seal, fluid and filter. The transmission is full of fluid, I have reverse,1st and 2nd gear only. No 3rd or (OD) 4th gear I tried to shift through the gears manually with the gear shifter with no results. The check engine light is NOT on in the insturment panel.
Toddbrandon28
Sep 26, 2014 7:26 AM
perry2326
Oct 19, 2013 10:25 PM
UnRumble
Feb 15, 2010 3:39 PM
efxr6wagon
Dec 3, 2009 11:45 PM
atomheartmother
Jun 29, 2008 9:41 AM
