Cavalier power window switch question
My '05 cavalier 4-dr has a cluster of window switches in the center console. The driver's window has occasionally refused to work--particularly when really cold outside--but now it doesn't work at all. I pulled the switch unit out of the console, thinking I'd just swap that window's connector with one of the back ones I never use--thinking the driver's switch may be bad...and only found two connectors! Before I start pulling the unit apart, could someone offer some clarification of how four windows operate off of just two multi-plugs? (all the other windows work fine) Thanks!
The switch is sending power to the motor, but the motor is stuck or the regulator is jammed somehow. Looks like I need a new door unit. Thanks for your suggestions.
Thanks for your help. I can see the driver's window regulator has already been replaced in the past, and when it does work, it operates fine. Yesterday the window had again randomly stopped working. I took the switch assembly out, sprayed it full of contact cleaner and when back in place, the driver's window worked, but the right rear would go down, but not up! I discovered new ones are available for $14.00 on eBay, kicked myself for wasting time cleaning it and ordered a new one. MAYBE that'll do it. Or, it'll be motor & regulator time, as you thought.
MyBowTieGuy
September 21st, 2011 1:12 PM
