Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Master power window switch replacement
Old May 12, 2013 | 8:22 PM
billharmon2's Avatar
Default Master power window switch replacement
Can anyone tell me how to remove the arm rest trim to get at the switches. I have removed the two screws under the the handle. I have tried prying on the trim it moves but doesn't come loose. I have a switch for the drivers side window that is sticking and won't raise the window. It will make the window go down but not up. The only way to get the window up is to hold the switch and star the car. The window goes up three inches at a time every time the car is started.
Old Jun 17, 2013 | 6:14 AM
wrobbin's Avatar
Repairing a power window switch is to make sure it is the switch that is at fault. While the switch is the most likely culprit, it is not the only component that can go bad in the power window circuit.
Old Jul 14, 2013 | 6:57 PM
Switch Doctor's Avatar
Default Chevy Master Window Switch
Here are some guides that may help you with your issue http://www.switchdoctor.net/removal-installation and I would definitely check here for prices, best priced switches here http://www.switchdoctor.net/chevrole...ow-switch.html
Old Aug 26, 2013 | 2:08 AM
andyabott's Avatar
MAster window switch can only be change when you have confirmation that the fault only from switch and for changing the switch you should to have expertise and equipments otherwise you can do from any garage or car care center.
Old Feb 16, 2021 | 11:14 PM
ricante's Avatar
have you figured out how to remove the switch? I'm trying to replace my switch as well. I was wondering if i need to remove the door panel to get to the switch or I could replace the switch without removing the door panel.
Ke'aloha Crytser
Oct 16, 2020 1:30 PM
jsharp007
Nov 28, 2011 1:34 AM
Spider
Sep 24, 2009 8:21 PM
NJGTP
Oct 3, 2005 9:52 PM
