Platform: J-body
Cavalier power window switch question
Old Feb 15, 2020 | 3:58 PM
Bowtie Bill's Avatar
Default Cavalier power window switch question
My '05 cavalier 4-dr has a cluster of window switches in the center console. The driver's window has occasionally refused to work--particularly when really cold outside--but now it doesn't work at all. I pulled the switch unit out of the console, thinking I'd just swap that window's connector with one of the back ones I never use--thinking the driver's switch may be bad...and only found two connectors! Before I start pulling the unit apart, could someone offer some clarification of how four windows operate off of just two multi-plugs? (all the other windows work fine) Thanks!
Old Feb 15, 2020 | 5:10 PM
I would check for power in to and out of the switch..if ok...check for power at the window motor. if no good...check for broken wires in the door A-pillar,
Old Feb 16, 2020 | 8:17 PM
The switch is sending power to the motor, but the motor is stuck or the regulator is jammed somehow. Looks like I need a new door unit. Thanks for your suggestions.
Old Mar 1, 2020 | 5:17 PM
Jiyu's Avatar
It's not the switch, the motor is kaputt. Common problem on Cavs. There's YT vids out there if you want to do it yourself. I've replaced two on mine myself, getting rather good at it....
Old Mar 2, 2020 | 3:46 PM
Thanks for your help. I can see the driver's window regulator has already been replaced in the past, and when it does work, it operates fine. Yesterday the window had again randomly stopped working. I took the switch assembly out, sprayed it full of contact cleaner and when back in place, the driver's window worked, but the right rear would go down, but not up! I discovered new ones are available for $14.00 on eBay, kicked myself for wasting time cleaning it and ordered a new one. MAYBE that'll do it. Or, it'll be motor & regulator time, as you thought.
billharmon2
Sonic (Aveo)
Feb 16, 2021 11:14 PM
biggun6ss
Oct 23, 2015 12:52 AM
MrChevy
Dec 27, 2009 9:15 AM
NJGTP
Oct 3, 2005 9:52 PM
