Platform: J-body
Dash Gauges
Old Apr 11, 2026 | 4:58 PM
44lawrence's Avatar
Default Dash Gauges
My 04 Cavalier temp, tack & speedometer dash gauge needles are "all over the place". I read there are shops that rebuild GM dash gauges . I will remove the dash unit, send it to them for the fix. Anyway can anyone recommend a reputable shop with a reasonable price & good turn around . I hear this is pretty common with the older GM's.
Thanks
Larry
Old Apr 13, 2026 | 5:19 AM
RD_Atlanta's Avatar
If you haven't done so, it might be good to connect a scanner and ensure that the scanner displays the same numbers correctly. The point being is if the scanner displays the values correctly then you're suspicions are probably correct that all four stepper motors are failing. While its certainly not impossible, it's not as typical for all four stepper motors fail.
I personally can't recommend a shop because I prefer to R&R the stepper motors myself. All four stepper motors can be had for about $16 on Ebay. It just requires some soldering skills.
https://www.ebay.com/itm/14259915488...Bk9SR4jpz-SwZw
realnice67
Chevelle & El Camino
Jan 10, 2016 2:21 PM
jonnyg25102
Apr 7, 2014 2:12 PM
tinyroe
Sep 7, 2009 9:51 AM
tdiddy
Cobalt
May 10, 2009 3:38 PM
KP1972
May 9, 2007 12:02 PM
