Platform: J-body
Engine Light and ETS off
Old Nov 12, 2010 | 9:09 PM
Anthonyfilm's Avatar
Default Engine Light and ETS off
Hello friends
This is my first post; I got at 98 Z24 with 225k miles, the 'check engine' light is on, with a blinking 'ETS off'. I read in an earlier post several months ago the problem is the TPS and needs to be replaced. But I do not have any shifting problems (the other poster had shifting issues), my question to you fine experts is my problem indeed the TPS?
Also, in the previous post the 'forum advisor' mentioned the computer needed to be reset after installing the new TPS, I assume any local shop can do this, but not advanced auto parts or autozone is this true?
By the way my transmission fluid leaks a bit too. I appreciate all the advice I can get, thanks.
Anthony
Old Nov 12, 2010 | 10:46 PM
MDTAHOE's Avatar
Professional Mechanic
What are the codes?
Old Nov 13, 2010 | 5:44 AM
Originally Posted by MDTAHOE
What are the codes?
I'll take the car over to autozone this morning and get the codes read, then I'll get back to you. Thanks for your patience
Anthony
Old Nov 13, 2010 | 11:20 AM
What are the codes?
The engine codes are '301', the guy at autozone says I need new plugs. I'll go ahead and put the new ones and I'll let you know what the result it.
Thanks Anthony
Old Nov 13, 2010 | 1:49 PM
I replaced the spark plugs and the plug boots; the 'check engine' light and 'ETS off' light went away. But after 10 minutes of driving it, only the 'ETS off' light came back on. The thing I notice now when I drive, the acceleration is sluggish (especially from a stop), like there isn't sufficient power, also there's a sputtering whenever step on the gas. I value your sage advice, what else can be going on with my car?
Thanks Anthony
o.valdez
Dec 17, 2011 10:46 PM
psd7.3
Dec 22, 2010 8:23 PM
Mr. Vann
Nov 25, 2009 7:24 PM
Deteoni
Mar 28, 2009 1:39 PM
wings
Aug 8, 2006 1:15 PM
