Platform: J-body
engine swap!!!!!
Old May 2, 2007 | 8:39 PM
bigworm105's Avatar
Default engine swap!!!!!
i need some info about a engine swap.. i have a 1993-1994 cavy and its seen its better days n i was wondering how much work it would be to swap a new motor i guess the 2.2l form a 200-2003? if anyone has some info thatd be great... Thanks
Old May 6, 2007 | 3:15 AM
ruffrider285's Avatar
Default RE: engine swap!!!!!
you would probly have to change the mounts, and the intake, also you would most likely need the engine wiring harness for the new engine because the distributors are in different places on the 2000's and 1990's...
Old May 6, 2007 | 12:40 PM
i also forget to tell you, the transmissions are different too...If i were you to make it alot easier i would find a 97,98,99 with low miles....that way you can keep your transmission and the mounts will be the same, all you would have to do is switch the intakes.
cueman
Feb 6, 2012 9:37 PM
BigSteve1206
May 16, 2006 8:50 PM
cleveman1
May 1, 2006 1:05 PM
Iowajeepin
Chevelle & El Camino
Apr 2, 2005 1:50 PM
