Platform: J-body
Fan not running
Old Jul 26, 2018 | 5:45 AM
isaacm's Avatar
Default Fan not running
Hi guys I have a problem with my 2009 cruze 1.6LS engine over heating. is for the first time that the fan is not running. the engine peaks up heat very fast after starting the engine.
Old Jul 26, 2018 | 5:54 AM
First check your fuses and the fan relay. If they are good check the temperature sender and the wiring to the sender.
Old Jul 26, 2018 | 6:24 AM
isaacm's Avatar
Will do! thank you
