Platform: J-body
fuel gauge is slow to respond to changes
Old May 19, 2024 | 10:54 AM
nighttimedaydreamer's Avatar
Default fuel gauge is slow to respond to changes
So I finally replaced the O2 sensor in my newer 2004 Cavalier LS sport, automatic, 4-door, 2.2 ecotec and it is driving fairly well now, but it has an issue that I have not seen in Cavaliers before, the fuel gauge is slow to respond to changes in fuel level and the car will surge when moving slow. I noticed driving the car home from the seller that the gas level was slowly rising, but I filled it up and made sure the gas cap was on correctly and when I started back up the fuel gauge indicated a full tank, so I though that it might be working. However, I drove 150 miles, at which point the fuel gauge read a little less than 1/2 tank, so I filled up, but this time the gas gauge stayed at half a tank. By the time I got home 30 minutes later the fuel gauge read slightly below full, which seems to be a fuel gauge that is taking longer than normal to adjust to the fuel level. Now the second issue that I think is related is that the car will surge when driving at low speeds. I notice this when backing up/pulling into parking spaces, as I will simply let the car pull itself in reverse when I back up (not pressing the gas) and then brake as needed to slow the car to a stop and switch to drive. Sometimes when I do this, after the car has rolled forward a few feet, it will surge pulling to car forward very rapidly, and has put me in some close-call situations, due to the close proximity of parking lots. Also, it will do this when I drive up the hill leading out of my neighborhood, as the car will have a hard time shifting when driving slowly up this hill, but when it does shift the car surges forward just like the parking scenario above. Now I figured the fuel gauge motor is bad, but I wanted to see if anyone has encountered these 2 issues in tandem before and if it could be an indicator for a bad fuel pump or fuel pressure sensor. I am just afraid of replacing the gauge cluster and then the issue being a bad fuel pump or fuel sending unit. I am wondering if these are completely unrelated, but figured it would not hurt to ask.
Old May 19, 2024 | 1:39 PM
try to keep it to one issue per thread please.
measure the fuel level sensor voltage to see if it's a problem with the sensor or your gauge. (schematics are on charm.li)
As for surging, smoke test for vacuum leaks, including the vacuum booster and EVAP system.
Old May 20, 2024 | 9:54 AM
Thank you, mountainmanjoe, your response was exactly the type of advice I was looking for, I am bad at getting caught up in what I "think is happening, but not actually happening, I get fixated on a trace/unlikely issue and just can not think reasonably." Your suggestion put things back in perspective. Thank you for the guidance, and I will keep threads to singular issues going forward. I actually still have an evap smoker tester from back when I built one to test for leaks on my old clunker Cadilac. I will see if I can get a family member to pull this from storage so I can test it, I can not believe I did not think of this as a potential issue, I have never done a leak test on my first Cavalier, but this could be a good test for it too. I will research the healthy range of voltage for the fuel level sensor and thank you for telling me where to find the schematics. I will see where this leads me. Thank you so much!
Silent Screamer
Avalanche
Mar 12, 2022 1:53 AM
Longtime Chevy
Nov 1, 2021 3:16 AM
ChipM
2007 - 2013 (GMT900)
Mar 6, 2021 5:22 PM
hockeyfan
Sep 22, 2018 11:36 AM
stantonbox
Jan 2, 2008 11:42 PM
