Fuel Gauge HELP!
Old Jan 2, 2008 | 7:00 PM
stantonbox's Avatar
Default Fuel Gauge HELP!
I'm gaining enough courage to repair my fuel gauge. The fuel gauge reads empty then full then somewhere in between while driving. My friends have convinced me to replace the fuel level sensor inside the fuel tank. I still think the problem could be a faulty connection. I figured to inspect the wiring connections during the tank removal. What I have found so far is most part stores will only sell a complete fuel pump w/ level sensor ($290) and the local Chevrolet dealer estimates $800 to replace the fuel pump and sending unit. I finally found a parts store that can supply the level sensor only ($78 plus shipping). Does anyone have experience in removing a Tahoe's fuel tank? I believe a special hose clamp tool is required to remove three hoses. Also, I will try to run the Tahoe to as near empty as possible. Any other advice out there? Thanks.[:-]
Old Jan 2, 2008 | 7:08 PM
ZX1100F1's Avatar
Default RE: Fuel Gauge HELP!
What year is your Tahoe?
Before I dropped the tank and took after the sender I would take a multimeter and make sure that was the problem.
It could be a bad gauge.
Old Jan 2, 2008 | 11:40 PM
stantonbox's Avatar
It is a 2002 Tahoe. This problem first occurred about 3 years ago and went away after one day. It came back about 2 months ago and has been more persistent.
I have a multimeter but wonder if the time and effort required to test the dash gauge would be as much work as replacing the sending unit.
Old Jan 2, 2008 | 11:42 PM
stantonbox's Avatar
And, the LOW FUEL display works each time the fuel gauge drops to Empty. This could support an assumption the dash gauge is functioning ok.
JohnG20
Oct 12, 2013 11:26 PM
santa6
Jun 23, 2013 2:14 PM
hfdff
Jul 26, 2010 9:09 PM
scottkern3
Dec 7, 2009 7:53 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
