Platform: J-body
Guys got oil leak problem need help.
Old May 24, 2008 | 3:03 PM
deziking's Avatar
Default Guys got oil leak problem need help.
well its a 2003 Cavalier 2.2l. So i've been finding oil leaks right under the power steering pump next to the oil filter housing. And no its not the left over oil after replacing the filter because I had cleaned the area onces and week later the oils back and I don't see any oil spots around the filter housing either. got the picture rite here showing the arrow.
So I looked under neat and I saw that the car has bad trans pan gasket cause I see fresh fluid out between the gasket and the pan. I'm still wondering where the heck is this oil dripping out of? I did see oil on the oil pan bolts but only on couple of them. But where the heck is the oil dripping from the top? I'm just thinking of doing the trans gask and oil pan gasket this weekend at home. anyone got any other suggestions?
Old May 24, 2008 | 7:48 PM
ruffrider285's Avatar
Default RE: Guys got oil leak problem need help.
I would change those gaskets then see if it still leaks. Its most likely your oil pan gasket.
Old Dec 28, 2012 | 10:06 AM
dylandrums12's Avatar
New User
Awaiting E-mail Confirmation
Did you ever find out what was causing the leak? I have the same problem and cant figure it out
91fixeruper
Astro
Mar 21, 2009 12:19 AM
sandlercd_22
Jan 5, 2008 9:33 PM
Proper
Jul 25, 2007 5:03 PM
antmesa
Aug 28, 2006 3:35 PM
