Headlight Issues
Have a 2000 cavalier which i am repairing after hitting a deer on right front. The headlights have never given me any problems up to this accident. Basically, i have had to replace the ps headlight assembly, bulb socket, fender, airbags, etc. Once I got all together, the passenger side low and high beam work fine, as well as side marker and blinker. The drivers side light barely lights on low, and is dim on high. I replaced both bulbs, and switched sides to no avail. I have checked wiring on pass side since bulb socket was destroyed in accident, no corrosion or cut wires that i have found so far. Once you drive for awhile, then both lights on low seem to be dim. Any suggestions?
garyv990
February 11th, 2015 9:52 PM
Lwags
April 14th, 2010 8:18 PM
