Platform: J-body
Heating and A/C Problem
Old Nov 1, 2015 | 4:24 PM
Kevin Engle's Avatar
Default Heating and A/C Problem
I have a 2000 Cavalier that I purchased recently. I have had a problem with the heat/air coming out of just the front vents which turned out to be a vacuum line with a hole in it and I fixed it. But now, when you turn it to floor or defrost, the air comes out of the front vents as well as floor or defrost. Any suggestions on where to start? Also, it will only blow heat or air on the 2 highest settings, not on low or low-medium.
