Platform: J-body
HELP
Old Aug 17, 2006 | 3:10 PM
jlanuevo36's Avatar
Default HELP
My 1999 cavalier has some transmission problems.....
When I put it in reverse it wont go in reverse when i push the gas....
When i drive it, it takes awhile to shift into 2nd....i have to let off to make it shift on its own....Please can anyone help me and tell me the cost of this problem...
I changed the tranny fluid too....
Old Aug 17, 2006 | 10:52 PM
beckeruti's Avatar
Default RE: HELP
it could be a bunch of stuff
do all the gears work
in reverse does it want to go but doesnt or does it just rev up
is it a 3 speed or a 4 speed
Old Aug 18, 2006 | 5:58 AM
jlanuevo36's Avatar
Default RE: HELP
its a 4 speed......and when im in reverse it just revs up.....when i drive....it takes awhile to shift to 2nd.......about 4000 rpm it shifts and sometimes i have to let off.......any suggestions??
Old Aug 18, 2006 | 6:08 AM
jlanuevo36's Avatar
Default RE: HELP
actually i dont know if its 3 or a 4 its a cavalier z24 1999 does that help ne?
Old Aug 18, 2006 | 1:30 PM
rodfoster's Avatar
Default RE: HELP
well, it seems as though your trans is getting bad. but, when you changed the fluid did you change the filter? do you have the right amount of fluid back in it? it is a 4speed, i believe all j cars after 96 or 97 had a 4 speed (i think) but anyways you may have an internal tranny problem! i would suggest taking it to a trans shop, anyone in that line of work should know pretty quick if it's a clutch pack inside, or something else really quick. (of course they will want you to leave it there for repair, but just tell them you want an estimate for now) then compare the price of repair versus swapping trannys
Old Aug 18, 2006 | 2:17 PM
beckeruti's Avatar
Default RE: HELP
maybe ur tcc is stuck
Old Aug 18, 2006 | 7:36 PM
jlanuevo36's Avatar
Default RE: HELP
how much do you think its gonna cost me??
Old Aug 20, 2006 | 1:22 PM
beckeruti's Avatar
Default RE: HELP
depends where u take
trannys are expensive to work on
try to get two qoutes before letting someone fix it
its hard to give u a price
one place could say u need a new tranny
which could be up to 2 grand
or another place could just fix it
maybe a couple hundred bucks
its hard to give a price on trannys
theres so much to a automatic
good luck
Old Aug 21, 2006 | 3:25 AM
NCHEVYHEVN's Avatar
Default RE: HELP
I worked with a transmission guy for a couple weeks and he said most of the time you just have to end up pulling them and tearing into to see what's the problem. Not sure if this is true but my guess is if you took it to a trans shop then their going to want to pull the trans out or at the very least drop the pan to look.
Old Aug 21, 2006 | 6:18 PM
jlanuevo36's Avatar
Default RE: HELP
how much do you think its gonna cost me to repair the transmission.....cuz im not paying 2 grand on it (worth more than the car)
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
