Platform: J-body
little black box
Old Feb 26, 2024 | 8:08 PM
44lawrence's Avatar
Default little black box
Can someone please tell me what a little black box is behind the glove compartment & is beside the blower motor on my 2004 Cavalier? It has a small 2 wire plug & next to impossible to get too. It was making a knocking noise so puled the plug. Everything seems to work but it must do something.
Thanks
Larry
Old Feb 26, 2024 | 9:57 PM
Nothing comes to mind. Can you post a photo please? Are there any part numbers stamped into it?
Old Feb 26, 2024 | 11:21 PM
44lawrence's Avatar
There's no way, I could only see it using a mirror & light while trying to fit my head under the dash. I could probably get at it through the back of glove box if I made a 3" hole . BUT you can't remove the box without taking half the dash out.
Old Feb 27, 2024 | 12:25 AM
it's probably an actuator for one of the HVAC doors getting stuck. So if you want to fix it, you'll have to disassemble anyway.
Old Feb 27, 2024 | 7:26 AM
44lawrence's Avatar
Yea that's what I was reading, the HVAC control door. The only way I'd deal with it is cut through the back of the glove box, then making a plastic repair panel. Taking that dash apart in order to remove the glove box is crazy. Anyway thanks for the reply.
Larry
Expendablenate
Jan 28, 2015 6:47 PM
Warspawn
May 9, 2011 10:29 AM
usmcsmith
May 21, 2007 8:59 PM
