Platform: J-body
Loud squeaking noise when at low speeds straight and turning
Old Mar 5, 2021 | 5:34 PM
Benjamin DuLaney's Avatar
Post Loud squeaking noise when at low speeds straight and turning
I have a loud squeaking noise and it happens at very low speeds while turning and or at below 10 mph. 2002 cavalier base coupe 2.2l non eco tech, AC is not on when this occurs.
Old Mar 6, 2021 | 1:38 AM
oilcanhenry's Avatar
Do you have hydraulic power steering? (pretty sure you do) Might be the pump or the steering box need repair or replacement.
Old Jun 10, 2021 | 10:19 PM
DSalmon03's Avatar
To me this sounds like a bad serpentine belt or tensioner, I had similar problems to the ones you're describing and I ended taking apart my wheel wells to check the serpentine belt on my Cavalier. Lo and behold the belt tensioner was cracked in 5 places, got new belt tensioner and no more squeals when turning, If I were you I'd start there as it's probably the cheapest, and good luck getting anything in there it is the tightest space I've ever worked in. Here's a video of a step by step.
Randy Stanfield
Nov 24, 2020 7:39 PM
Nuchevy65
Nov 2, 2017 11:02 AM
chevcav05
Mar 26, 2015 12:55 AM
Tahoe Mom
Nov 3, 2014 11:35 PM
Znelwonders
Feb 18, 2009 7:53 PM
