Platform: J-body
Need a cavalier expert/ diagnosis expert
Old Jun 8, 2013 | 1:13 PM
tragichip's Avatar
Default Need a cavalier expert/ diagnosis expert
So here is the scope, I keep making threads on this topic but I have done a lot over the past 3 months so here is where I am at.
So my car has a rough idle where it bounces between 900 - 1000 rpm (sounds like it has lumpy cams). When you give it gas or just idle it up and a bit and hold it the miss goes away and runs smooth. I have hooked it up to a computer and at idle all cylinders miss across the board, but on idling up the misses clear out. I have replaced coils, plugs, injectors, injector harness, and egr. With these replacements I have squeezed a bit of performance out but still the same rough idle, I have checked vacuum lines as well. I'm wondering if maybe its a bad wire to the pcm but like that a shot in the dark I really have no idea where to go from here. My car is pulling a P0300 which is random misfire and a bank 1 sensor 2 low volts and heater malfunction which is the back 02 (after cat) so don't really know, help would be great
tragichip's Avatar
If anyone is seriously about really looking into this problem I can post a video of exactly what its doing
hunterjo
Jan 2, 2013 10:01 AM
ssumners
Sep 30, 2012 2:43 PM
pkjosh
Nov 7, 2011 8:46 PM
ourbigtruck
Mar 4, 2011 8:20 PM
cor
Camaro
Dec 6, 2008 2:13 PM
