Platform: J-body
Need help
Old Mar 12, 2014 | 11:42 PM
columbo's Avatar
Default Need help
Hello, just singed up for the forum to hopefully get some help. I have a 2004 cavalier with an oil leak on the back passenger side of the engine that appears to be coming from a bolt. I have attached a picture and circled the bolt where the oil appears be coming from. I am just trying to identify this bolt and maybe a torque spec, so I can tighten it or if need be replace a seal.
Thanks in advance.
Old Mar 13, 2014 | 11:21 AM
You need to remove it and replace the seal.
Old Mar 13, 2014 | 6:26 PM
columbo's Avatar
What bolt is that?so I know what part to get. Thanks for the info
*edit-I believe this is the timing chain tensioner, is there a way to replace the seal without opening up the timing chain?
be_Martinezr
Oct 6, 2014 10:19 AM
1stTahoe
Apr 19, 2012 9:44 PM
badabingman
Mar 4, 2009 8:26 PM
