Platform: J-body
No voltage to module
Old Sep 11, 2015 | 12:57 PM
Roflpwn344's Avatar
Default No voltage to module
i had just finished putting a new 2.2 into my cavalier and the engine cranks and all lights work but I am getting no voltage to the control module resulting in no spark. Any thoughts?
Old Sep 11, 2015 | 1:30 PM
what module, what connector and what pins om the connector did you check?
any theft lights on?
can you connect a scan tool and communicate with the pcm?
Old Sep 11, 2015 | 1:37 PM
Roflpwn344's Avatar
It would be the spark control module. And yes the anti theft light is on. I have tried every GM method I have found online to try and reset the anti theft.
Old Sep 12, 2015 | 8:41 AM
if the theft light is on solid after cranking it will inhibit spark output from the ignition control module.
did you swap out anything else? ipc, pcm?
what year cav so we are on the same page here? what engine 2.2 ecotec or 2200?
Old Sep 12, 2015 | 9:34 AM
Roflpwn344's Avatar
The motor was the only thing swapped. It is a 97 with a motor from a 96
Old Sep 13, 2015 | 2:22 AM
fyi in cav circles you have a 2200 not a 2.2
if the theft light is on...post the codes
Old Oct 23, 2015 | 11:10 PM
gage3780's Avatar
[B I do believe that year they had the 2.2 L OHV, 2.2L OHC Ecotec 2.3 L OHC and 2.4 L OHC Ecotec's. But I could be wrong. Would be helpful knowing which one. Most likely the 2.2 OHV or OHC
Old Oct 23, 2015 | 11:38 PM
2.2 ecotec went into cav's in 2003. he has a 2200
pjm333
Aug 19, 2015 3:40 PM
mystrg
Mar 26, 2008 3:19 PM
schorner
Nov 1, 2006 8:42 PM
twfinch
Sep 26, 2006 2:38 AM
Jonathan93
Aug 8, 2006 4:03 PM
