Platform: J-body
Oil
Old Nov 9, 2017 | 7:14 AM
Steve111's Avatar
Default Oil
My 2005 Chevy cavalier is leaking oil onto transmission coming from under oil filter housing. Would this be from the oil sending unit?
Old Nov 9, 2017 | 7:51 AM
oilcanhenry's Avatar
Do you have the 2.2 liter Ecotech motor? It has a built in oil filter placement on the motor and you only change the oil filter cartridge and the oil seal on the 32mm wrench plastic cap. Might be the seal is bad or the filter cap was mis-threaded and/or needs replacement, Best way to tell is place some cardboard under the engine to see where the leak is coming from as soon as you are done driving while the oil is hot and has some pressure. Oil sending units rarely leak,IME, they just go bad sometimes.
Old Nov 9, 2017 | 8:13 AM
post some pics
Old Nov 9, 2017 | 10:29 AM
Steve111's Avatar
Yes I have the engine above. I realize the filter that it has and it is not leaking from the filter housing. Oil is coming from the engine under the oil filter housing and colleting on top of the transmission.
Old Nov 9, 2017 | 5:08 PM
Well, i'd clean the area that its leaking from with some engine cleaner or something, and see exactly where the leak is at. Could be lots of things, besides the oil pressure sensor.
